Today’s question comes from Jim, who says, “I would like to place a wire-type TV antenna in the attic. We’re about 25 miles from the local broadcast towers, so I’m sure that would work. What antenna would you recommend?”
Putting a TV antenna in the attic is a popular way to keep it out of sight and out of the elements. But before you settle on an antenna model and placement, you need to consider the pros and cons of attic installation, how you’ll get the signal to your TV or Tablo device and your distance from local broadcast towers.
Pros and Cons of Attic Installation
Height is an important factor in getting a strong signal to your TV antenna. Mounting it in your attic certainly helps with that, keeps things looking tidy and avoids potential damage from the elements. It may also be less daunting for DIY installation than climbing up on the roof.
Considering an attic installation because of Your Home Owner’s Association or landlord? By federal law, they cannot prevent you from mounting a TV antenna outside in a sole use area.
The trade-off is that an attic placement puts an obstruction – your roof – between your TV antenna and the towers. Common roofing materials like asphalt shingles will moderately reduce the overall signal strength reaching your TV antenna, while metal roofing, radiant heat barriers and other heavy-duty construction materials can completely block over-the-air signals.
Getting Signals from the Attic to Your TV
Because Tablo streams over-the-air channels to compatible devices over Wi-Fi, your Tablo and TV antenna don’t have to sit next to your television. This gives you the flexibility to place your antenna wherever it gets the best signal. However, you should never place your Tablo device in an attic or any other room that isn’t temperature controlled. Extreme heat, cold, humidity and temperature swings can cause the electronics to fail.
For this reason, you’ll need to run some coaxial cable from your attic antenna to your Tablo device, or directly to your television if you don’t have one. Keep the run as short as practical, because the longer the cable between your antenna and the tuner, the more likely the signal is to weaken.
Consider Tower Distance Before Settling on Placement
At about 25 miles from the broadcast towers, Jim is well within the 35-mile range where over-the-air reception is typically strongest. In most cases, a smaller indoor TV antenna should provide a strong enough signal.
Anyone living this close to local broadcast towers, Jim included, should avoid choosing too powerful a TV antenna. Even with the potential obstructions caused by an attic installation, a high-powered antenna could overload the tuners in your Tablo device or television, leading to reception problems instead of improvements.
If the goal of an attic placement is to keep your TV antenna out of sight, many indoor models are already designed to blend into your décor. And because Tablo streams wirelessly, the antenna can go in any less conspicuous spot that gets a good signal, instead of in the living room next to your TV.
There Is No Single Best Attic TV Antenna, Just the Right Antenna
Without more information, it’s tough to provide a specific TV antenna model recommendation, but Jim’s distance from local broadcast towers generally calls for a smaller indoor TV antenna rather than a larger, more powerful outdoor or attic-mount model.
While any TV antenna can go in your attic if its range suits your distance from the local towers, no antenna models are designed solely for attic use, though you’ll likely see larger models marketed as ‘indoor/outdoor’ or ‘attic/outdoor’ while shopping.
Start by finding your local towers. If you’re not sure where they are, use our online tower locator at tablotv.com/towers. If you’re close, a smaller, lower-power indoor TV antenna is generally sufficient.
Look for an antenna with a range only slightly higher than your distance from the towers. For Jim’s 25-mile distance, that means a model rated between 35 to 50 miles. Stick with quality brands like Antennas Direct, Mohu, Channel Master, Winegard, Antop and Televes. These brands provide accurate range estimates, use time-tested designs and are built with quality materials.
