Tablo's out-of-home streaming service - Tablo Connect - lets you access your network-connected Tablo to stream live TV and recordings on your paired devices, anywhere in the world.
The app for Live TV, Tablo lives alongside your other on-demand streaming services like Netflix and live TV streaming apps like Sling TV to deliver your hometown news, sports and live events as they air, or on your schedule, wherever you go.
Tablo Connect is a subscription-only feature that is easily enabled in your network-connected Tablo's setting screen, to let you access your live and recorded hometown TV through Tablo over WiFi or cellular data connections anywhere in the world.
Supported devices must be synced with your Tablo on its home network before departure.
Once your device has been paired, you can watch live or recorded TV, set future recordings and even adjust some of your Tablo's settings, just like you would at home.
Video streamed to a paired device using Tablo Connect is uploaded via your broadband internet connection, so video will use and be affected by the upload speed of your internet connection.
To enjoy Over-the-Air TV on-the-go, network-connected Tablo DVRs support the use of Tablo Connect on the following devices:
Tablo Connect is also supported when casting to Chromecast via paired Android mobile devices and PCs.
Roku does NOT currently support Tablo Connect.
TV-Connected Tablo DVRs do NOT support Tablo Connect.
The ‘best’ device for Tablo Connect depends on your needs, but keep these considerations in mind:
Portability - Mobile devices are great for small screen viewing. Watching on a TV at your vacation home? Consider a Fire TV stick or box.
Internet Upload Speed - When streaming video via Tablo Connect, you are limited by the upload speed of your external internet connection from your ISP. A minimum upload speed of 5 Mbps is required.
WiFi Connections - Some public WiFi networks can restrict the streaming of video or the use of internet ports required to access Tablo Connect.
Cellular Connections - There are generally no restrictions on cellular connections, but streaming video via Tablo Connect can use approximately 2-7 GB of data per half hour program, so an unlimited data package is recommended.
Apple fans can enjoy live and recorded TV via the Tablo apps for iPhone and iPad.
Benefits
- Access to all Tablo screens and filters including settings
- Supports Tablo Connect
- Supports setting manual recordings
- Can be used with older generation Apple TV devices via Airplay
- Available in the US and Canada
Drawbacks
- None
We Recommend
Any newer generation iPhone or iPad running iOS 12+ can be used with the Tablo app.
Android fans can enjoy live and recorded TV via the Tablo app for Android smartphones and tablets.
Benefits
Drawbacks
- None
We Recommend
Any newer generation Android device running Android 4.4+ can be used with the Tablo app.
If you want to watch TV while working on your Windows PC, you can enjoy live and recorded content from Tablo via the Windows 10 app.
MAC users can access a web-based app at my.tablotv.com via the Safari browser.
Benefits
- Access to most Tablo screens and features including settings
Drawbacks
- Web app is not fully supported on all platforms/browsers - soon Safari on MAC will be the only officially supported browser option.
- Windows 10 app is not supported on MAC operating systems.
We Recommend
The Tablo Windows 10 app for PC and the web app via Safari for MAC computers.
Amazon Fire TV is the 2nd most popular streaming device for use with Tablo OTA DVRs.
Benefits
- Supports Tablo Connect & Automatic Commercial Skip
- Support for over 7,000+ paid or free apps and games
- Range of affordable devices including set-top-boxes and sticks
Drawbacks
- User interface pushes Amazon Video content; can be off-putting for non-subscribers
We Recommend
The 2019 Amazon Fire TV Cube or the Amazon Fire TV Stick 4K MAX for the best experience.
Apple fans should consider the Apple TV HD or the Apple TV 4K (2021 model).
Benefits
- Super-fast in-app navigation
- Control video playback using Siri voice assistant
- Access live and recorded local TV on the same device as purchased content from iTunes
Drawbacks
- Expensive – price starts at $150 USD
- Not compatible with TV-Connected Tablo DVRs
We Recommend
Apple TV HD, Apple TV 4K
The Nvidia SHIELD platform is great for gamers and home theatre hobbyists because of its power and flexibility.
Benefits
- Controlled with a gamepad or optional remote control
- Access to a wide range of popular apps and games from the Google Play store
Drawbacks
- Expensive – starts at $199 USD
- Cannot control Tablo app using Google voice controls
We Recommend
Nvidia SHIELD TV PRO or NVIDIA SHIELD TV (stick).
Unlike previous generations of Chromecast, the new Chromecast wtih Google TV is a true streaming device with its own remote.
Benefits
- Affordable but capable hardware
Drawbacks
- Not as powerful or flexible as other Android TV-based devices
We Recommend
Chromecast with Google TV (2020)
Now that you know more about Tablo Connect-compatible devices, here's some additional reading that you might find helpful:
If your home router is enabled with a Universal Plug n' Play (UPNP) function, setting up Tablo Connect is as simple as clicking a checkbox in the settings screen of your network-connected Tablo DVR.
If your router requires additional configuration, get next steps for port forwarding for most popular routers
Read through our port forwarding guide and still unsure of how to proceed? Get help from our support gurus!
Get a detailed overview on how Tablo Connect works and what its settings mean
